My 2001 (with auto trans) is beginning to indicate it needs new motor mounts. when I got it used, 6 years ago - it had just had new motor mounts - probably cheapest like its replacement vinyl rag top.
I have only put about 10K on the car. I'd like to put in a set of mounts that will last. The miata-speed competition mounts seem like a decent set - BUT THEN - I saw the polyurethane competition set with varying hardness bushings - for ride stiffness. These are a completely different & tougher design with a trough bolt - NO RUBBER TEARING HERE - they have a different 3 bolt mounting base, & even with the softer bushing - will probably outlast me. Since my mechanic gets $200. to change mounts, & since my car seems hard on them - it may be a better investment to go with the tougher new design. Anyone else use these ? How often do the Differential Mounts need replacing - how can you tell ?
Thanks, C.
Thanks, C.
