Oem replacement key
  • Oem replacement key
    Hi all,
    I lost my 2nd OEM key and have only one key + Remote now.
    its a 2002 and the key has chip in it and has to be programmed.
    local dealers quote about $67 for the key and $80 for programming.
    are they are alternatives available ?
    Thanks
    2002 LS Black Miata
    Find a locksmith and ask them to do it. My guess is it will run you about $50 a key.
    2007 True Red Miata
      Thank you, I will ask around the locksmith's .
      In my search i found that nb2 has an immobilizer chip and the new key will need to be programmed .
      if not programmed the key might open doors and trunk but not start the engine.
      2002 LS Black Miata
        I wouldn't mind spending the $$ a key costs - to get the Immobilizer deactivated - so I could buy & use $3. keys. Any way you could GLUE the expensive chip key to the immobilizer - then use
        regular keys ???
