I have a 93 stock Miata but changed to 15 inch rims. I need new tires. I have 175/65/15's. Will 185/65/15 fit without scrubbing? What are largest tires anyone has on a stock frame Miata? Thanks
What are largest tires i can use?
Originally posted by Locomonkeyboricua View PostFor 15 inch wheels 195/50/15 or 195/45/15. Is the largest i would use on non turbo miata..
But if you've got the power to actually use them - 225's work well on a NA, 245's if you don't mind a "significant" pull and roll on the fenders.
One factor nobody seems to have brought up is wheel offset. You can throw 225-45-15 tires on an NA without having to remove the inner fenders, but only if they're mounted on +36 offset wheels. You need to place the center of the tire in about the same spot in the wheel well as the stock setup. Unless you're harnessing 300 horsepower. You don't need that much section width, not to mention weight. The original wheel and tire combo weighed just a bit over 30 pounds. Pick the wrong wheel and you can get 15" wheels that weigh that much. As you increase in size, rotational mass goes up, and your beautifully handling car turns into a understeering monster.
If this is a weekend toy, that will be used the full calendar year, go with a performance all season tire like a Yokohama S-Drive in 205-50-15. If it's just a fair weather toy, you can go with a more extreme tire like the RS-3, or Nitto R888.Red '91, MSM longblock/BEGI-FM hybrid turbo w/2871r/3"Enthuza/Hydra2.7/700cc/Ohlins/
RacingBrake11"BBK/SS HDDD/Nakamae everything/KGWorks/Zoom/We're done!
I sure am liking the looks of these 245s on my new ride :)
Originally posted by oldgrayfrog View Post15 x 10's Nick? No way those fenders didn't get rolled! What's the offset +48?
Originally posted by eyeballs View PostThat right there is a good looking car!sigpic
