Motor Mounts
  • Motor Mounts
    Returned mine to OEM today. Much less vibration thru out car. Only problem is engine shakes when ac engages at idle. Not a vibration but a definite shake in the driver's seat as well. Smooths out with slight throttle. I cant remember if I tighten the driver side rubber mount to the bracket with a socket wrench. I know I at least finger tightened it and probably did with a socket wrench as well. I could not remove the bracket completely due to not enough room, had to attach rubber motor mount thru the wheel well. My question is this shake typical or did I miss tightening this bolt. Why does it smooth out with throttle? I cant see the motor mount moving though.
