Need help with hood hinge
  • Need help with hood hinge
    I bought a set of hood struts for my 91 Miata. The stud (bolt) that would hold the strut flange on the passenger side is stripped. I'm guessing that it and the other stud is attached to a bar that's sandwiched between the upper and lower sheet metal of the hood. If anybody else has dealt with this, I would appreciate your advise.
    Thanks,
    Frank
    You could try a thread chaser
    Sent from my iPhone using Tapatalk
    Slip 'N' Slide
