What's up guys, my 2002 Miata is having a problem everytime I shift. The knob kinda makes a little grinding/click/clack noise whenever I shift. What could be the problem? Your help is greatly appreciated.
2002 Mists SE grinding gearbox
Shifter could be loose, or tye nylon shift bushing is gone. Is this a new problem or a new to you car?David Luney - Suwanee GA
[email protected]
I didn't really notice it until 2 weeks ago. I kinda disregarded it as normal. But when I tried shifting in my brother's 350z, his gearbox shifts like butter. So then I was thinking it could be the tranny fluid. I also read it could be the "gearbox fluid" but IDK if there is such thing since I know NOTHING about cars. But since I'm a complete noob, I kinda just hoped it was normal and didn't do anything about it.
https://www.youtube.com/watch?v=jEWtj0gFa1s <-- pretty apt description of what a busted shifter bushing looks like
https://www.youtube.com/watch?v=B09ljiFZfaM <- how to swap it, I'm fast forwarding thru it, but it seems pretty comprehensive. You don't need a metal/brass bushing, the stock nylon works fine when it's not completely busted. It lasted 10 years, it'll probably last another 10.
gearbox, tranny fluid - same thing. Does it rattle with the clutch in? might be throw out bearing, might just need a bleed.
Originally posted by kung fu jesus View PostFailing clutch hydraulics. Replace the slave cylinder.
Sent from my Nexus 6P using Tapatalk
^ Completely agree.
When the gears grind when shifting, the clutch isn't disengaging. This is most often the hydraulics not pushing the release bearing fork far enough to completely disengage the clutch. The clutch hydraulics are typically pretty weak and wear out. Easy enough and cheap enough to replace everything at once. That 949 kit is a good deal.
If the clutch slave fails, you're going to likely need a tow.
Eh, autozone has the slave cylinder for $20 with a lifetime warranty. I've used that warranty 3 times.
I do hate the curly-q hardline on the slave, all of my miatas have the hydraulic line upgrade.
http://949racing.com/miata-clutch-line.aspx
