Just wondering if anyone had advice for replacing the valve stem seals. Bought new ones today, and will hopefully be doing this over the weekend to fix the burning oil on startup issue in my 95. Any advice is greatly appreciated.
Tips and advice for valve stem seal replacement
uh huh... have you ever had a valve train apart before???
91 BRG #3240
Have you ever seen a guy driving a Mazda Miata and thought, “man, I wish that was me!”? Neither have I.
Aside from the fact that this car screams “I’m fabulous!” from every angle, this car was made for the guy who wants to drive down the coast with his new scarf from Wal Mart flapping in the breeze. If you own a Miata you're one of three things: in the closet, a woman, or a ******bag.
Originally posted by amaff View Postuh huh... have you ever had a valve train apart before???
I've done cams before, and helped assemble SBC's & BBC's, but never had to mess with with the valve stem seals. I'm paranoid and like to make sure I research as much as possible before tearing into a car.
Originally posted by Pitt View PostLast edited by MrVito; 03-05-2009, 09:56 AM.
All 1.8L are the indeed the same size.In The Garage:
1995 Flared Turbo R Package - Thor // 1999 Brilliant Black Turbo - Harbinger // 2015 Infiniti Q40
75 IN/LBS for the cam caps.
Trying to get the retainers back in place can be a PITA with the head still on the car, but it's doable if you have a second person there. Me and hector actually just did this to a car in the shop. They make a special tool that removes the keepers in a split second, but putting them back in doesn't work so well. We had to make our own tool and place them in by hand.
Also, the seal puller tool is worth it to get. Like $30 and makes removal a 5 second job. A deepwell 10mm socket is he perfect size to press the new seals down into place.ITBs RULE!!!!!!!!!! AGAIN!!!
I'm using ITBs on stock internals!!
Chean Chay: they dont have pho in mexico
Corporation: n. An ingenious device for obtaining individual profit without individual responsibility.
-Ambrose Bierce
here's the thing. if you disagree with someone's opinion, having better hair does not make you right. it makes you a ******bag.
