Ok os i just noticed today, and im not sure if it has to do with me running synthetic oil, but my oil pressure is lower than it has been on conventional oil. It used to run about 25psi at idle and about 50psi when driving. now its got about 12-15 psi at idle, and about 32psi when driving. It getting that time when i need to change my oil again, but i dont know why its doing this. It was a quart low so i filled it to the max line, but i have the same result. I wonder if the guage is acting up. What do you think, thanks guys.
Low oil pressure
mine ran low like that till i got my turbo kit now it runs about 50-60 driveing depending on oil temp i also use full synthetic but i use lucas oil 10w 301990 Red Turbo Miata BEGI kit GT2860RS
RC550 Injectors/walbro fuel pump/MSPNp/1.6l with built bottom end/ factory head and original valve train.:banana:
