Hey guys. I just got back home to drop something off and shut the car off. Was running fine all day and started every time without issue. Go bac to the car maybe 5 minutes later, turn the key, and nothing. It's got power to everything, but it will not turn over. Any ideas? I kinda need the car for tomorrow, so I'm kinda annoyed by it >_< I'm thinking it's the starter.
Won't start >_<
If you have power to everything, but no starter action, it may be the key switch. Do you have a lot of stuff on your key ring? Switch failure is more common (although not sure if you're getting the accessories to work, but not the Start/Run), but if you find it's the starter, I have a good one you can get. Strong enough to bend a rod. :DIn The Garage:
1995 Flared Turbo R Package - Thor // 1999 Brilliant Black Turbo - Harbinger // 2015 Infiniti Q40
off topic, sorry...but i remember one day i was on the Newnan bypass and did a lil burnout and when i shifted to second (i have long legs), my right knee bumped the remote on my keychain when i lifted up, and like a 1 in a 1,000,000 thing it turned the key back to the a position- but it still revved, and radio worked...needless to say after having a volvo my 1st thought was (sh!t i need a transmission) until i lookedOriginally posted by VERY FLUSHTrust me.my education is far surpass other people
Originally posted by RotorNutFD3S View PostIf you have power to everything, but no starter action, it may be the key switch. Do you have a lot of stuff on your key ring? Switch failure is more common (although not sure if you're getting the accessories to work, but not the Start/Run), but if you find it's the starter, I have a good one you can get. Strong enough to bend a rod. :D"Never let go of what you got, because it might just be all you'll ever get"
Well I was going to give you mine... That's $0.00. I have a new one that is for my 6-speed.In The Garage:
hey... if the new starter still doesn't work.. Check all your grounds. I had ground that looked perfected, but was dirty and it stopped me from getting 100% power to the starter. Everything else worked perfect in my car but just won't get power to the starter.
Good luck1988 323 GTX--- The toy now :D
