So i finally got around to tearing down my motor. the connecting rod bearings are scored, spun and/or smashed to ****. it appears as though the crank has walked causing the con. rod bearing failure, but there is NO damage to the mains. If possible i would like to re-use the con. rods. What do I need to check on the con. rods?
engine is a 1.8 out of a 1999.
