So as some may know i ran into clutch problems a few weeks ago, with my 91 na. Its funny how when you take something apart, you tend to find more and more parts needing replacing.
So i removed the tranny, and found that my rear tranny seal was leaking. After getting it out, i found that my throwout bearing had mushroomed over, and wore out the pressure plate. Under that, the disk was warn to the rivets. After removing the flywheel, i found that my pilot bushing is warn pretty bad. After doing that, I found that my rear engine seal and the oil pan gasket were leaking.
So today, i was ready to lift the motor up to do the oilpan gasket, and i went to lossen up the motor mounts, and found that 2 of the 3 bolts holding the motor mount to the engine block had backed out and had fallen out somewhere, or that the mechanics that maintained the car for the previous owner didnt put them back in. So i was doing mountain runs and autox, on pretty much one motor mount. Kinda scary.
Anyway, my *****ing is over, I only wish that my miata could handle abuse like my datsun.
