Need help on a voltage check
  • Need help on a voltage check
    Ok I need someone to check voltage on there miata for me. Perfer an NA6 but don't see why a NA8 would cause a problem.
    I need a voltage reading of the ign for the gauge cluster. For an NA6 it will be blk/yellow and be on the black connector to your gauge cluster and be the second pin from outside-in.
    Another spot someone could access, would be on the passenger side. Under the dash(may or may not be easily accessible) The dash harness connects to the main harness.
    Thank you. I am currently trying to trouble shoot why my gauge cluster is getting no main 12volt source.
    Blk/ylw has 12v. Let me know if you need another reading, one of my cars doesn't have a dash, so it's easy to check.
    Self proclaimed Miata junkie - 90' Track Rat - Flex 10/6 - 2871 - DIYPNP -
      Thanks, but I finally got my dash working.
