Turbo oil drain
  • Turbo oil drain
    I am getting ready to drill a 1.6 oil pan for the oil drain.
    Alot of the pics and builds I have looked at have no AC in place and others I have owned either had no AC or utilized the built in drain nipple on the passenger side of the block. I am keeping the AC on this car, so I am trying to figure out the right/best place to drill. Anyone have a link to a pic of a build with AC. Just want to doublecheck before I drill it.
    Thanks in advance.
    RE: Turbo oil drain
    It's really easy Kurt. My car has A/C and I did it with everything in place. Go between the first and second oil pan bolt, in the center of that panel.
    I tried to take a good pic just now, but that might not be possible with the car on the ground.
      RE: Turbo oil drain
      found a pic of an oil pan.
        RE: Turbo oil drain
        Ahh...so under the AC bracket then?
        My engine is on the floor so I have complete access to it.
        The AC bracket is attached however for reference.
        I am not really worried about drilling I just want to get it in the
        right spot. Hehehe...okay that sounded suggestive..:lol:
        [attachment=208]
          RE: Turbo oil drain
          correct, in the top pic I posted you can see the bottom of the a/c bracket
            RE: Turbo oil drain
            Wow- I didn't realize that it mounted that low on the pan. How high is the oil level on that end when the pan is at the proper level? Must only be a 1/2" or so...
            | 90 Miata | Turbocharged Stock Mazda FE-dohc 2.0L engine swap | 302whp 281ftlbs |
              RE: Turbo oil drain
              There really shouldn't be any level of oil there, it would be flowing down to the sump. No?
              Kurt's bracket does look a wee low. I bet it would adjust up a little.
              Corky says it doesn't matter if you tap below the oil level. And I believe him, but I still got mine as high up as possible. I actually drilled with the a/c bracket in place, but had to remove the bracket to thread the pipe fitting in. (the "corners" of the fitting would strike the bottom of the bracket when turning)
                RE: Turbo oil drain
                Kurt + turbo = :wtf:
                  RE: Turbo oil drain
                  Originally posted by Doppelgänger
                  Kurt + turbo = :jawdrop:
                  Fixed.
                    RE: Turbo oil drain
                    Kust, just remove your dipstick and plumb it into that hole.... you don' tneed the dipstick anyway :lol:
                      RE: Turbo oil drain
                      The HKS 1.8 kits actually used a setup like that. :lol:
                      The 1.6 kit however used the existing drain nipple
                      on the passenger side of the block. Other turbo cars/engines
                      I have owned were drilled higher on the pan then AC will allow...or on the front corner.
                        RE: Turbo oil drain
                        Which is why I'm swapping to a MSM pan on my 1.8. Bolt on and go. :)
                          RE: Turbo oil drain
                          The MSM pan also have a fitting on the pass. side for a oil breather/catch can....
                            RE: Turbo oil drain
                            or oil cooler :cool:
                              RE: Turbo oil drain
                              And i'd be willing to be that if someone reproduced those parts and sold them, people would buy them because they don't want to tap the pan :)
                              If I had access to those parts, i'd try to do it.
