How long do you think it should take to remove and reinstall the front bumper on my NB? (for body kit fitment purposes)
Removing And reinstalling front bumper
taking old bumper off = 10 minutes
installing new glass bumper = 5 minutes
The "hard" part on the stock bumper is getting to all of the clips along the bottom between the bumper and the air-guide, then there are the pesky clips that hold the splash shield to the bumper in the wheelwells...as they get gunked up with dirt/sand and can be a PITA to get out.
Originally posted by simontibbett View PostWhat clips are you all speaking of? I only have 3 bolts up top and zip ties on the corners lol, for easy removal and when I hit something it doesn't break stuff.
but its not a lengthy process at all.
well it does not seem like the front bumper fits very well at all. It looks like the front of the frame is in the way. Do you think i'm doing anything wrong?2000 Brilliant Black & tan: 1.9L Sr20 turbo with begi log manifold and SGDP--DIYPNP--ID1000s--Bilstien coilovers--MSW type 16 wheels--FM stage 1 clutch w/ 10.3lb flywheel
i removed the big plastic piece and tried again. the two metal thing that come out of the frame are in the way. Will those have to be removed(if possible)?2000 Brilliant Black & tan: 1.9L Sr20 turbo with begi log manifold and SGDP--DIYPNP--ID1000s--Bilstien coilovers--MSW type 16 wheels--FM stage 1 clutch w/ 10.3lb flywheel
diagram of bumper
i found a diagram of the bumper. The Green arrow is pointing to the piece that you said to remove (i removed it). The red arrow are pointing to the metal pieces that seem to be part of the frame. The two pointy things did not have any bolts that i could tell. maybe they are on the other side of the frame?2000 Brilliant Black & tan: 1.9L Sr20 turbo with begi log manifold and SGDP--DIYPNP--ID1000s--Bilstien coilovers--MSW type 16 wheels--FM stage 1 clutch w/ 10.3lb flywheel
