fuel injectors?
fuel injectors?
95 R-package 6 speed, MSPNP, AEM WB UEGO, HDHCDD, Walbro 190lph, stock inj, GT2860RS V-band, ARTech Manifold, 3"TBE, TiALMVS 38mm WG, Blitz BOV, NO BOOST!
79 Corolla Gutted, weber 32/36, Header, Volk Rays, Ghetto slammed :lol:Tags: None
550cc/min is about 52 lbs/hr.
Math:
550/10.5=52.4
I don't know anything about those injectors, but do know that Jerry wouldn't recommend anything that isn't good.DIYAutoTune.com
Delphi makes original equipment for a lot of GM vehicles (they used to be a part of GM?). Seems that DIY Autotune offers quite a bit of GM OEM parts.sigpic
will these plug right in? or what needs to be done to make them work.(aside from a tuning capability)Last edited by redrumracer; 01-14-2009, 07:01 PM.
They likely won't "plug right in" (even the RCs that came with my FM kit had different harness connectors), but even so it is a simple splice of two wires. If you are nervous about splicing into the factory wiring harness, you can probably track down some harness connectors that will do the trick (plan on $40-70 for 4 of them).
Here is some info from the DIY website:
Here are some known applications for these injectors. Most will require tuning instead of being a "drop in and go," but they won't require fabrication, either.
BMW: M20, M30, M50, M52, S50, S52
Ford: 1986 through 1995 5.0 Mustang, 1992 through 1998 4.6 modular motor
GM: L98 TPI V8, LT1 and LT4
Mopar: 3.9, 5.2 and 5.9 Magnum through 1999
These are likely to fit many VW, Chrysler, Porsche, Audi, Volvo, and some Subaru and Mitsubishi applications as well. We hope to expand this list soon, but if your application is not listed here, please check the size of your injectors before ordering. If you have a motor where the injectors physically fit the intake but the plugs don't match, we sell plugs for these injectors in both crimp on and pigtail varieties separately.
EV1 connector EV1 pigtail
Even if your harness will not plug directly into these injectors, these plugs can be spliced into your harness to convert your engine to EV1 injectors as long as they fit your fuel rails and manifold. In that case these injectors wouldn't be plug and play, they would require a bit of splicing or crimping to existing wires.sigpic
Sean, what are you going to be using to control fuel?
I guess since you're looking at the RC550s, you already have that covered. So if you are looking for a direct drop-in and plug-and-play with no wiring involved, you can use 89-91 (S5) non-turbo RX-7 injectors which are like 460cc, or the S5 Turbo ones that are 550cc.
I used a set of S5 n/a injectors on my 96 and controlled them with a Apex-i SAFC and was running 10psi on a JRSC kit.
He's going with MS. Probably a PnP unit.In The Garage:
1995 Flared Turbo R Package - Thor // 1999 Brilliant Black Turbo - Harbinger // 2015 Infiniti Q40
Originally posted by redrumracer View Postwill these plug right in? or what needs to be done to make them work.(aside from a tuning capability)
IIRC you can go up to about 310cc (toyota Supta 7MGE non-turbo) and still idle ok on the stock computer.
oh yeah I was talking to marty (the guy that used to drift the pink miata) and I think he still has his old link, he never managed to sell it. you can probably score it for cheaps now.
As for injectors, deatschwerks sells straight drop in miata injectors up to 600cc, but they're gonna be more expensive than rx7 injectors.sigpic
IIRC Links for OBDI (like Marty's) will not work with OBDII cars. But I could be wrong there.In The Garage:
so what should i do? im gonna be running the MSPNP, and Walboro 190hp fuel pump, i can spend alot on RCs, or go with the RX-7 fuel injectors, what else is out there?95 R-package 6 speed, MSPNP, AEM WB UEGO, HDHCDD, Walbro 190lph, stock inj, GT2860RS V-band, ARTech Manifold, 3"TBE, TiALMVS 38mm WG, Blitz BOV, NO BOOST!
