I have a weird popping sound every time I hit the brakes. It's just a pop. It sounds like it's coming from the left front, I can't see anything visibly wrong though. Any clues what to check?
Popping Sound...
Last time I had something like that happen, one of the bolts on the front sway bar mount was loose and the metal retainer for the bushing was hopping around on the threads.In The Garage:
1995 Flared Turbo R Package - Thor // 1999 Brilliant Black Turbo - Harbinger // 2015 Infiniti Q40
Well there ya go then. :DIn The Garage:
Can you get a picture of how they are breaking? OEM bar? Bushing condition?In The Garage:
Stupid question, but to cover all the angles, you are using the brackets (or the same size brackets) that came with the bar correct?
If so, maybe look into something along these lines then: http://www.flyinmiata.com/index.php?...umber=13-36600
I remember these being discussed at length on one of the forums, but basically some people have seen the mounts come off the car, or they just break like your case. These mounts are supposed to cure that issue. Nick (nickt93) has them on his '95 currently, IDK if he was having an issue or not though.In The Garage:
No problem. I just got an FM bar, hasn't seen any road use on my car yet, so I'm going to be keeping an extra close eye on that area since I've been seeing more and more issues pop up online.In The Garage:
Maybe their bars overpower the frame? :lol:In The Garage:
I'm running the Racing Beat 1.125" front bar (not that ***** 1" FM bar) and using the Mazdaspeed mounts. They were a freaking ***** to install, but comparing the before and after, there's nothing to compare. Beefy!Friday nights 7-9 PM, go to www.ksuradio.com and listen to Owl Oldies. Visit our Facebook group for any requests and suggestions. Classic Kevin - 60s and 70s on OWL Radio
