Results 1 to 18 of 18
Thread: Soft top latches repairable?
  1. #1
    Join Date
    Jan 2010
    Location
    Powder Springs, Ga
    Posts
    96
    Default Soft top latches repairable?
    Is it possible to tighten up a latch for the soft top? Not only did I get a tear in the original top on my '99 today, but the passenger side latch kept popping loose on the way home today. It seems that the small safety button you press to release the top is no longer touching the main latch. This is after, on accident, I left the top down last night and had to run outside a few minutes after the downpour started at 3:30 in my boxers to put the top up.
    It has not been a good day for me to say the least.
    Second question is there anyone that has any in there garage for sale? Top or latches?
    Thanks
  2. #2
    Join Date
    Aug 2009
    Location
    Rydal, Northwest Ga. Mountains and winding back roads
    Posts
    511
    Default
    Here's a link that may help you.
    http://www.miata.net/garage/top_latch/index.html
  3. #3
    Join Date
    Jul 2008
    Posts
    8,691
    Default
    NB latches are notoriously crappy that way. They often get replaced with good working early NA latches. Let me know if you need some.
    http://www.mx5atlanta.com/forums/image.php?type=sigpic&userid=13&dateline=123560545  3
  4. #4
    Join Date
    Apr 2009
    Location
    Decatur
    Posts
    6,971
    Default
    The procedure is, 1) unscrew three bolts holding NB latch 2) Discard NB latch 3) attach superior NA latch with the three screws 4) step back and admire your craftsmanship!
    Red '91, MSM longblock/BEGI-FM hybrid turbo w/2871r/3"Enthuza/Hydra2.7/700cc/Ohlins/
    RacingBrake11"BBK/SS HDDD/Nakamae everything/KGWorks/Zoom/We're done!
  5. #5
    Join Date
    Sep 2008
    Posts
    4,491
    Default
    Quote Originally Posted by oldgrayfrog View Post
    I don't disagree, but there is a way to repair your latches if you want.
    Take the latch off the car and examine it. The failure is easy to see. The lock tab is made of a metal that is too soft and wears over the years. As it degrades, the latch is able to open without the lock tab striking its retainer. You can fix this by adding material to the lock tab. Mix some JB Weld. Allow it to sit until it starts to get thick. Apply the thick JB to the tab. Shape it and allow it to set. After it's completely hard, you can file/grind away excess JB until the tab is the shape that you want. Then you can paint the latch assembly black to hide the repair.
    Free repair if you have JB, a dremel, and an hour or so.
    Much easier to replace the latches with ones from an NA.
  6. #6
    Join Date
    Apr 2009
    Location
    Decatur
    Posts
    6,971
    Default
    They are not expensive from Kurt. I'd just suck it up and have a nice top again.
  7. #7
    Join Date
    Jan 2010
    Location
    Powder Springs, Ga
    Posts
    96
    Default
    I am just gonna have to suck it up and get a new top, really want the money to go elsewhere on the car but I am not to fond of a duct taped top. Only question is it I tackle it myself or not. Does a new top usually come with new latches as well?
  8. #8
    Join Date
    Jul 2008
    Posts
    8,691
    Default
    Quote Originally Posted by lavarocs View Post
    No. A brand new top must be installed on your frame as well.
  9. #9
    Join Date
    Jan 2010
    Location
    Powder Springs, Ga
    Posts
    96
    Default
    Quote Originally Posted by metalman View Post
    Ok. Well I have the passenger latch off right now attempting the JB weld method on the safety latch. When I looked closer it was almost a 1/16 off from even touching the main latch. Both are fairly worn.
  10. #10
    Join Date
    May 2009
    Posts
    38
    Default
    I drilled and tapped a hole in the engagement surface and put in a small screw to let the head of the screw take up the space. I have done several like this, even NA latches.
  11. #11
    Join Date
    Jan 2010
    Location
    Powder Springs, Ga
    Posts
    96
    Default
    Thanks for all the input. I got the JB weld on yesterday and filed it down a little this morning and it seems to have worked fine. Now I can keep a look out for some NA latches.
  12. #12
    Join Date
    Sep 2008
    Posts
    4,491
    Default
    It should hold up fine.
  13. #13
    Default
    Where can i find this NA style latch? looking all over with google and coming up with nothing
    thanks
  14. #14
    Join Date
    Jul 2008
    Posts
    8,691
    Default
    Quote Originally Posted by chrisl View Post
    thanks
    I have some available.
  15. #15
    Default
    In my moms NB she just puts the sun visor in the way to hold it in place, as a temp fix
  16. #16
    Join Date
    Aug 2012
    Location
    kennesaw ga
    Posts
    73
    Default
    that could work unless like me you decided the sunvisor is utterly useless. since if i flip it down to block the sun it blocks 80% of the windshield. so i unscrewed them and pulled it out.
  17. #17
    Default Thanks
    Quote Originally Posted by engled View Post
    Followed your suggestion and it is working beautifully. Saved me a pretty penny and it took about 15 minutes.
    Thanks again,
    Ken
  18. #18
    Default
    I'm a mediocre mechanic, but the JB weld solution takes about 10 minutes. Just remove the latches; put a bead on each latch (the latch itself, not the smaller catch). Let it harden, and you're good to go. There's enough tolerance so that you don't need to worry about filing it down. All in all, it's faster and easier than ordering new latches! The most time consuming part of all this is trying to follow the intricate and ingenious alternatives that much better mechanics have come up with.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
